The report can be shared directly as a permanent web link without having to export or print the document. The recipient can only view the report, including the link to view the flight plan on the map, and cannot make any changes. The report can also be printed or saved as a PDF.
Navigation
As a SORA report can be quite long, we have built an easy-to-use navigation system. You or the external recipient can use it to navigate between the individual chapters at any time.
Presentation of all results
All calculations, results and declarations as part of the SORA process are presented clearly and completely in the SORA report. We have taken particular care to ensure that the presentation is based on known structures so that the processing time by the authorities can be minimized as far as possible.
