Roof and facade inspection with drones
Find and compare suitable drone service providers for your project
Customer reviews
Customer satisfaction is our top priority. We are therefore delighted with the many positive comments about our service.
Hire a drone service provider for spontaneous or regular inspections of hard-to-access building areas such as roofs, roof systems and façades and be safer, faster and more cost-effective than with conventional methods. Identify weak points and assess future risks with the help of high-resolution images, thermal analyses or surveys. Easily comply with regulations for energy-efficient building renovations and the granting of subsidies.
Recording types and results
dach gebäude inspektion drohne
Aerial photography - Photos/Videos
Photos and videos are the simplest type of drone footage. As with conventional cameras, the drone takes individual photos or a continuous video, but these benefit from the unique perspective from the air and make even hard-to-reach places easily visible. These images therefore provide a completely new overview and level of detail.
Thermal imaging
In addition to simple photos and videos, special drones also offer the possibility of providing thermal images from the air. Thanks to the better overview provided by drones, more areas or areas that are difficult to access can be captured more quickly. Thermal imaging provides you with important information about possible damage or poorly insulated areas on roofs or facades.
Dachinspektion Markierung schadhafter Stellen
Orthophotos and orthomosaics
Digital, drone-based data can be processed and compiled into high-precision orthomosaic maps. Each pixel contains 2D geo-information (X, Y) and provides precise measurements, such as horizontal distances and surface information. This data can be overlaid on digital plans to track construction progress and serve as a visual communication tool and site documentation.
Advantages of drone footage for roof and façade inspections
Cost-effective
Where appropriate scaffolding had to be erected or lifting platforms procured for inspections before a qualified person could attempt the ascent, a single drone pilot on the ground is now sufficient. No expensive purchases, no lengthy set-up of additional equipment.
drohnen inspektion skyzr
Fast and flexible
Drones are quickly put into operation and ready for use. The actual flight can also be carried out in a fraction of the time otherwise required for a roof/facade inspection, while many more areas can be captured at once. The images can also be used afterwards for further inspections.
Safe
As a drone-based roof or façade inspection does not require a person to attempt a dangerous ascent, this variant is also significantly safer than the conventional method. In addition, this type of inspection generally does not disrupt ongoing operations at companies – the inspection can be carried out without having to start machines or stop other people from working.
How it works
Register
Register for free
Create job
Describe your requirements quickly and easily in just a few steps
Receive offers
Receive suitable offers from various drone service providers after just 48 hours
Why skyzr?
We support customers from a wide range of industries in commissioning drone-based services at the best price-performance ratio and obtaining high-quality data.
drohnenpilot einfach finden
Simple order entry
We minimise the time and effort you spend on hiring drone services and thus on unique photos, videos and data.
drohnenpilot zertifiziert
Certified drone pilots
High-quality results require a lot of experience. That’s why only certified and tested drone pilots are accepted on skyzr. In this way, we ensure legally compliant flight operations.
Offers within 48 hours
You are guaranteed to receive prompt offers from several drone pilots and can compare them directly with each other.
Efficient roof and façade inspection
Discover the impressive benefits of aerial photography for the roof and façade inspection industry. skyzr offers you access to professional drone pilots who create high-resolution aerial images for roof and façade inspections.
Drones offer an efficient and cost-effective solution for the inspection and maintenance of buildings, especially roofs and facades. By using drones, areas that are difficult to access can be inspected in detail without scaffolding or lifting platforms.
The high-resolution aerial images make it possible to detect possible damage, leaks or other problems at an early stage. This contributes to safety, value retention and optimized maintenance planning and avoids expensive repairs in the long term.
See for yourself the many possible applications and benefits of drone technology for roof and façade inspections. Successful inspection projects start with skyzr – your platform for professional drone service providers and meaningful aerial images.
